Ir para o conteúdo principal
Amazon Luna Controller Shell Replacement
O que você precisa
  1. Amazon Luna Controller Shell Replacement, Battery: passo 1, imagem 1 %32
    • Flip the controller over so that the back panel is facing up.
    Pergunte ao FixBot
    Comentar
  2. Amazon Luna Controller Shell Replacement: passo 2, imagem 1 %32 Amazon Luna Controller Shell Replacement: passo 2, imagem 2 %32 Amazon Luna Controller Shell Replacement: passo 2, imagem 3 %32
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
    Pergunte ao FixBot
    Comentar
  3. Amazon Luna Controller Shell Replacement, Faceplate: passo 3, imagem 1 %32
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
    Pergunte ao FixBot
    Comentar
  4. Amazon Luna Controller Shell Replacement: passo 4, imagem 1 %32
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
    Pergunte ao FixBot
    Comentar
  5. Amazon Luna Controller Shell Replacement: passo 5, imagem 1 %32 Amazon Luna Controller Shell Replacement: passo 5, imagem 2 %32
    • Once all clips are released, lift the front plate away from the controller.
    Pergunte ao FixBot
    Comentar
  6. Amazon Luna Controller Shell Replacement, Buttons: passo 6, imagem 1 %32 Amazon Luna Controller Shell Replacement, Buttons: passo 6, imagem 2 %32
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Amazon Luna Controller Shell Replacement: passo 7, imagem 1 %32 Amazon Luna Controller Shell Replacement: passo 7, imagem 2 %32
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
    Pergunte ao FixBot
    Comentar
  8. Amazon Luna Controller Shell Replacement: passo 8, imagem 1 %32 Amazon Luna Controller Shell Replacement: passo 8, imagem 2 %32 Amazon Luna Controller Shell Replacement: passo 8, imagem 3 %32
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
    Pergunte ao FixBot
    Comentar
  9. Amazon Luna Controller Shell Replacement, Joystick Cover: passo 9, imagem 1 %32 Amazon Luna Controller Shell Replacement, Joystick Cover: passo 9, imagem 2 %32
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
    Pergunte ao FixBot
    Comentar
  10. Amazon Luna Controller Shell Replacement, Shell: passo 10, imagem 1 %32 Amazon Luna Controller Shell Replacement, Shell: passo 10, imagem 2 %32
    • Gently grab the controller's circuitry and hold the bottom shell.
    • Pull the circuitry gently out from the shell.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
2Comentários do guia
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - Responder Compartilhar
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 27
Ao todo: 326
