Ir para o conteúdo principal
Amazon Luna Controller Joystick Cover Replacement
O que você precisa
  1. Amazon Luna Controller Joystick Cover Replacement, Battery: passo 1, imagem 1 %32
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Joystick Cover Replacement: passo 2, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement: passo 2, imagem 2 %32 Amazon Luna Controller Joystick Cover Replacement: passo 2, imagem 3 %32
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Joystick Cover Replacement, Faceplate: passo 3, imagem 1 %32
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Joystick Cover Replacement: passo 4, imagem 1 %32
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Joystick Cover Replacement: passo 5, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement: passo 5, imagem 2 %32
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Joystick Cover Replacement, Buttons: passo 6, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement, Buttons: passo 6, imagem 2 %32
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Joystick Cover Replacement: passo 7, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement: passo 7, imagem 2 %32
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Joystick Cover Replacement: passo 8, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement: passo 8, imagem 2 %32 Amazon Luna Controller Joystick Cover Replacement: passo 8, imagem 3 %32
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
  9. Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: passo 9, imagem 1 %32 Amazon Luna Controller Joystick Cover Replacement, Joystick Cover: passo 9, imagem 2 %32
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 216
