Introdução
With a defective charging port, you're going to have a hard time trying to connect your Kindle to a computer or charger. This can lead to problems when trying to charge your battery or when trying to update your Kindle. This guide will teach you how to change your charging port.
O que você precisa
Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
Attach the new battery by inserting the end of the orange power connector (the end not attached to the battery) clips into a little socket on the device (it's barely visible). You can tell when it clips in by the feel and sound. Make sure that when you put the new battery in, you first clip the connector in before you stick the tape down.
Be Aware: Your new battery might not be charged, so it may not power-on immediately! After replacing the battery, plug your Oasis in and let the battery charge to full capacity.
Locate the 2 Phillips screws (labeled PH 0) and remove screws using a screwdriver with a PH0 bit.
4 outras pessoas executaram este guia.
7 comentários
Where did you source a replacement charging port?
I also need one please, did you ever manage to find one?
Stefan B -
Since I don’t see an answer a year and a half later; I’ll ask the question again. Does anyone know somewhere to order a replacement charge port for this model? The replacement procedure doesn’t seem too difficult but I can’t find the Kindle Oasis part that is inclusive with the ribbon cable anywhere.
I also am trying to purchase a replacement. Anyone have any success?
Ditto .looking everywhere. Any ideas?
