Ir para o conteúdo principal
Amazon Kindle Oasis 8th Gen Back Panel Replacement
O que você precisa
  1. Amazon Kindle Oasis 8th Gen Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Carefully wedge the plastic opening tool between the back panel and the device to free the clips holding the back panel and the device together.
  2. Amazon Kindle Oasis 8th Gen Back Panel Replacement: passo 2, imagem 1 %32 Amazon Kindle Oasis 8th Gen Back Panel Replacement: passo 2, imagem 2 %32 Amazon Kindle Oasis 8th Gen Back Panel Replacement: passo 2, imagem 3 %32
    • Work your way around the back panel to free all the clips.
    • There are 5 clips on the long and thickest side of the oasis, and none on the others.
  3. Amazon Kindle Oasis 8th Gen Back Panel Replacement: passo 3, imagem 1 %32 Amazon Kindle Oasis 8th Gen Back Panel Replacement: passo 3, imagem 2 %32
    • Carefully remove the back panel from the device.
    • Gently peel the back panel away from the adhesive, being mindful to keep the adhesive strip in good condition so that it can be used again.
Conclusão
Nicholas Owens
Membro desde: 09/27/17
152 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S16-G5, Eyestone Fall 2017 Membro de USF Tampa, Team S16-G5, Eyestone Fall 2017
USFT-EYESTONE-F17S16G5
4 Membros
Autoria de 16 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 68
Ao todo: 5,734
