Ir para o conteúdo principal
Amazon Fire TV Cube Motherboard Replacement
O que você precisa
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, imagem 2 %32 Amazon Fire TV Cube Motherboard Replacement, Speaker: passo 1, imagem 3 %32
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: passo 2, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement: passo 2, imagem 2 %32 Amazon Fire TV Cube Motherboard Replacement: passo 2, imagem 3 %32
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: passo 3, imagem 1 %32
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: passo 4, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement: passo 4, imagem 2 %32
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement, Motherboard: passo 5, imagem 2 %32
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: passo 6, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement: passo 6, imagem 2 %32
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: passo 7, imagem 1 %32 Amazon Fire TV Cube Motherboard Replacement: passo 7, imagem 2 %32
    • Gently pry the motherboard up and off.
Conclusão
3 outras pessoas executaram este guia.
2 comentários
where do you buy the mother board ?
Sam Handa - Responder
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
futuregu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 1,661
