Ir para o conteúdo principal
Amazon Fire Phone Micro-USB Port Replacement
O que você precisa
  1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: passo 1, imagem 1 %32
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: passo 2, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: passo 2, imagem 2 %32 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: passo 2, imagem 3 %32
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Micro-USB Port Replacement: passo 3, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 3, imagem 2 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 3, imagem 3 %32
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: passo 4, imagem 1 %32
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
  5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: passo 5, imagem 1 %32
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
  6. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: passo 6, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: passo 6, imagem 2 %32
    • Unscrew the 1mm screw on the top left side of the phone
    • Maneuver the bracket off slowly
  7. Amazon Fire Phone Micro-USB Port Replacement: passo 7, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 7, imagem 2 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 7, imagem 3 %32
    • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
  8. Amazon Fire Phone Micro-USB Port Replacement: passo 8, imagem 1 %32
    • Unscrew the 3mm screw located on the top left side of the phone with a flat head
  9. Amazon Fire Phone Micro-USB Port Replacement: passo 9, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 9, imagem 2 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 9, imagem 3 %32
    • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
  10. Amazon Fire Phone Micro-USB Port Replacement: passo 10, imagem 1 %32 Amazon Fire Phone Micro-USB Port Replacement: passo 10, imagem 2 %32
    • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
  11. Amazon Fire Phone Micro-USB Port Replacement: passo 11, imagem 1 %32
    • Lift off bottom plastic piece with flat antenna cables
Conclusão
3 outras pessoas executaram este guia.
Kent Kawahara
Membro desde: 10/01/15
110 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-7, Maness Fall 2015 Membro de Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
Membros da 5
Autoria de 10 guias
2 comentários
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 2,447
