Ir para o conteúdo principal
Amazon Fire Phone Headphone Jack Replacement
O que você precisa
  1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • If the display is damaged use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, imagem 1 %32 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, imagem 2 %32 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: passo 2, imagem 3 %32
    • Power off your phone.
    • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, imagem 1 %32 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, imagem 2 %32 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: passo 3, imagem 3 %32
    • Press the single suction cup just above the home button.
    • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
  4. Amazon Fire Phone Headphone Jack Replacement: passo 4, imagem 1 %32 Amazon Fire Phone Headphone Jack Replacement: passo 4, imagem 2 %32 Amazon Fire Phone Headphone Jack Replacement: passo 4, imagem 3 %32
    • Remove the 1mm screw concealed in the headphone jack.
    • Afterwards the headphone jack will easily pop off.
Conclusão
Savannah Moen
Membro desde: 10/29/15
237 Reputação
Autoria de 1 guia
1Comentário do guia
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 2,059
