Introdução
If your camera has stopped working or has become damaged this guide will be the solution to your problem. We are confident that anyone can fix this. Good luck!
O que você precisa
Ensure that the device is turned off.
Holding the device firmly, wedge a plastic opening tool between the speaker cover and the device. Then pry up to separate it from the device.
Then begin to firmly pry up the plastic cover with the plastic opening tool.
Once you can fit your finger under the plastic cover, begin to slide your finger down the cover while simultaneously prying up.
Use a plastic opening tool to wedge between the screen and the device, while simultaneously holding the clip open from step 4.
Start to remove the screen from where the black plastic trim was removed and work the tool around the sides of the device. You will here small pops from the clips on the sides being released.
The Amazon Fire can now be opened with the two flex cables at the base still connected
Use the spudger to lift the the small white flap holding the narrow cable down.
Pull the narrow flex cable up and out to detach it from the motherboard.
Using a spudger gently lift the camera housing from the device.
The housing is held in by two pins at the edge of the device so you have to pull the housing from the edge of the device inward and then up.
Under the copper strip you will see one more flex cable that needs to be detached. Proceed to step 5 to remove.
