Ir para o conteúdo principal
Amazon Fire HD 8 Rear-facing Camera Replacement
O que você precisa
  1. Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 8 Rear-facing Camera Replacement, Screen: passo 1, imagem 2 %32
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 2, imagem 1 %32
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, imagem 1 %32 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, imagem 2 %32 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 3, imagem 3 %32
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, imagem 1 %32 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, imagem 2 %32 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 4, imagem 3 %32
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: passo 5, imagem 1 %32 Amazon Fire HD 8 Rear-facing Camera Replacement, Rear-facing Camera: passo 5, imagem 2 %32
    • Pop the camera out of the rear-facing camera casing by carefully pulling the orange cable with the tweezers.
  6. Amazon Fire HD 8 Rear-facing Camera Replacement: passo 6, imagem 1 %32 Amazon Fire HD 8 Rear-facing Camera Replacement: passo 6, imagem 2 %32
    • Flip up the tab on the ZIF connector at the end of the ribbon cable.
    • Grasp the underside of the orange cable with the tweezers and gently slide the camera out of the connector.
Conclusão
Alyssa Barrack
Membro desde: 02/24/16
855 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Leahy Spring 2016 Membro de USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 9
Últimos 30 dias: 15
Duração total: 1,989
