Ir para o conteúdo principal
Amazon Fire HD 8 Front Camera Replacement
O que você precisa
  1. Amazon Fire HD 8 Front Camera Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 8 Front Camera Replacement, Screen: passo 1, imagem 2 %32
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Front Camera Replacement: passo 2, imagem 1 %32
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Front Camera Replacement: passo 3, imagem 1 %32 Amazon Fire HD 8 Front Camera Replacement: passo 3, imagem 2 %32 Amazon Fire HD 8 Front Camera Replacement: passo 3, imagem 3 %32
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Front Camera Replacement: passo 4, imagem 1 %32 Amazon Fire HD 8 Front Camera Replacement: passo 4, imagem 2 %32 Amazon Fire HD 8 Front Camera Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Front Camera Replacement, Front Camera: passo 5, imagem 1 %32 Amazon Fire HD 8 Front Camera Replacement, Front Camera: passo 5, imagem 2 %32 Amazon Fire HD 8 Front Camera Replacement, Front Camera: passo 5, imagem 3 %32
    • Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
    • The gasket may pop out, but it can easily be put back in.
  6. Amazon Fire HD 8 Front Camera Replacement: passo 6, imagem 1 %32 Amazon Fire HD 8 Front Camera Replacement: passo 6, imagem 2 %32
    Comprar
    • Using tweezers, gently remove the white tape with the QR code.
    • Fold the camera back and use tweezers to gently remove the orange tab.
Conclusão
Dan Shimkus
Membro desde: 02/24/16
1.184 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-3, Leahy Spring 2016 Membro de USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
Membros da 4
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 1,776
