Introdução
In this guide, we will show you how to replace the front camera. Before you start, make sure your device is powered off.
O que você precisa
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
Quase terminado!
Conclusão
