Introdução
In this guide, we will show you how to replace the speaker on the bottom left of the device. Before you start, make sure your device is powered off.
O que você precisa
Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
Using tweezers, carefully lift the copper strip from the right side of the speaker.
Uma outra pessoa concluiu este guia.
Um comentário
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
