Ir para o conteúdo principal
Amazon Fire HD 8 Bottom Speaker Replacement
O que você precisa
  1. Amazon Fire HD 8 Bottom Speaker Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 8 Bottom Speaker Replacement, Screen: passo 1, imagem 2 %32
    • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
    • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
  2. Amazon Fire HD 8 Bottom Speaker Replacement: passo 2, imagem 1 %32
    • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
    • Be careful not to bend the screen by pushing it too far from the rest of the device.
  3. Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, imagem 1 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, imagem 2 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 3, imagem 3 %32
    • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
    • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
  4. Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, imagem 1 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, imagem 2 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 4, imagem 3 %32
    • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
  5. Amazon Fire HD 8 Bottom Speaker Replacement, Bottom Speaker: passo 5, imagem 1 %32
    • Using tweezers, carefully lift the copper strip from the right side of the speaker.
  6. Amazon Fire HD 8 Bottom Speaker Replacement: passo 6, imagem 1 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 6, imagem 2 %32
    • Remove the two screws located on the top left and bottom right of the speaker using a T4 screwdriver.
  7. Amazon Fire HD 8 Bottom Speaker Replacement: passo 7, imagem 1 %32
    • Lift the right side of the speaker and carefully unhook and remove it from the device.
    • Be mindful of the white wire connecting the speaker to the device.
  8. Amazon Fire HD 8 Bottom Speaker Replacement: passo 8, imagem 1 %32 Amazon Fire HD 8 Bottom Speaker Replacement: passo 8, imagem 2 %32
    • Set aside the black speaker and follow the white wire to its connection on the upper left side of the motherboard.
    • Using tweezers, gently pry the black clip upward from the board.
Conclusão
Uma outra pessoa concluiu este guia.
Marisa Holste
Membro desde: 02/24/16
677 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-3, Leahy Spring 2016 Membro de USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
Membros da 4
Autoria de 17 guias
Um comentário
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
Keven Paxton - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 37
Duração total: 4,156
