Ir para o conteúdo principal
Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
O que você precisa
  1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, imagem 1 %32 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, imagem 2 %32 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: passo 1, imagem 3 %32
    • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
    • Work your way around the device to free all the clips.
  2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 2, imagem 1 %32
    • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
    • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
  3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 3, imagem 1 %32
    • Use a nylon spudger to unclip the connection from the motherboard.
  4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 4, imagem 1 %32 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: passo 4, imagem 2 %32
    • Unscrew the two screws using a T5 screwdriver.
    • The camera lens are sensitive. Be careful when removing and handling camera.
    • Once freed from the screws, gently lift and remove the camera.
Conclusão
Omir Rosado
Membro desde: 09/30/16
725 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-4, Passmore Fall 2016 Membro de USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 586
