Ir para o conteúdo principal
Amazon Fire HD 10 USB Charging Port Replacement
O que você precisa
Instruções em vídeo
Conclusão
To reassemble your device, follow these instructions in reverse order. Be sure connection pins (in the center of the pad) have enough solder to reattach the the replacement micro-usb.
12 outras pessoas executaram este guia.
eCuration
Membro desde: 05/19/17
376.693 Reputação
Autoria de 234 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
3 comentários
Can you use usb replacement parts for fire hd 6, 7 and 8.9 for the fire hd 10?
custmadehancraf - Responder
Some English narration instead of the annoying music would be useful. Unsoldering looked rather magical, what was the heat source? Hot air gun under the board? You’re daubing on cleaner and flux, I guess, no idea what’s what. Paste solder?
Alan Corey - Responder
Is there a way to know if it's the battery or the charging port
Tech Reviews - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 14,713
