Ir para o conteúdo principal
Amazon Fire HD 10 Screen Replacement
O que você precisa
  1. Amazon Fire HD 10 Screen Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 10 Screen Replacement, Screen: passo 1, imagem 2 %32 Amazon Fire HD 10 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
    The right side with the power switch on top?
    Sonny Shear - Responder
    Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
    Thanks!
    Steve Ciciora - Responder
  2. Amazon Fire HD 10 Screen Replacement: passo 2, imagem 1 %32
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
    What is a ZIP connector? What does it look like?
    Beldenr - Responder
    Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
    Adam O'Camb -
  3. Amazon Fire HD 10 Screen Replacement: passo 3, imagem 1 %32 Amazon Fire HD 10 Screen Replacement: passo 3, imagem 2 %32
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Screen Replacement: passo 4, imagem 1 %32
    • Remove the screen and digitizer from the case completely.
Conclusão
26 outras pessoas executaram este guia.
Jaie Hillery
Membro desde: 10/07/14
1.718 Reputação
Autoria de 10 guias
Equipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro de USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
Membros da 3
Autoria de 22 guias
16 comentários
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Responder
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland -
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Responder
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Responder
What is needed to attach the screen back to the case?
Jimmy Lee - Responder
I think you just snap it on. Not sure, I haven’t fixed mine yet.
[deleted] -
what best double sided tape for kindle hd 10 digitizer repair?
carl schnitzer - Responder
Cheaper to buy a new one and keep the broken one in the car or garage.
Francisco Garay - Responder
This is true. Going forward, I’d recommend getting the kid’s edition no matter what. It is a great insurance policy. Amazon honors their warranty nicely…
Daniel Jacobovitz -
Does anybody know if the 2017 model uses the same screen and/or digitizer as the 2015 model?
bhicks0316 - Responder
That is only the glass, and not the LCD… This guide doesn’t include the steps to separate the glass from the LCD assembly…
Daniel Jacobovitz -
This did not work for me. I wonder if it changed in newer models ? I pried it open on the side, then the whole back cover came off. It was impossible to separate the glass from the rest without breaking it all. Wonder what I did wrong.
Lennart Pascal Tarris - Responder
Extremely simple and very well documented. Thank you for making the replacement less difficult. Just one question, how do you get the plastic tool to fit in between the screen and the frame? Mine wore out trying to scrape and push its way in there
Joseph Richard - Responder
Too bad the cost of the part is so high.
Charles Woznak - Responder
Anyone try using this screen in other projects? I am looking for an adapter for the ribbon cable to HDMI or DPSI
Joe Steele - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 41
Últimos 30 dias: 159
Duração total: 34,872
