Introdução
You will need to use the screen replacement guide as a prerequisite.
O que você precisa
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Uma outra pessoa concluiu este guia.
The right side with the power switch on top?
Sonny Shear - Responder
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Responder
