Ir para o conteúdo principal
Amazon Fire HD 10 Front Facing Camera Replacement
O que você precisa
  1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: passo 1, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: passo 1, imagem 2 %32 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: passo 1, imagem 3 %32
    • Avoid prying near bottom right hand side due to LCD Connector
    • Use a plastic opening tool to pry the screen up in the right hand corner.
  2. Amazon Fire HD 10 Front Facing Camera Replacement: passo 2, imagem 1 %32
    • Do not completely remove the screen yet as there is a ZIF connector connected.
    • Lift the screen and digitizer from the case.
    • You may need to use some force due to the glue.
  3. Amazon Fire HD 10 Front Facing Camera Replacement: passo 3, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement: passo 3, imagem 2 %32
    • Be mindful of the ZIF connector.
    • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
  4. Amazon Fire HD 10 Front Facing Camera Replacement: passo 4, imagem 1 %32
    • Remove the screen and digitizer from the case completely.
  5. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: passo 5, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: passo 5, imagem 2 %32 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: passo 5, imagem 3 %32
    • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
    • Make sure you place the screws in a safe location nearby.
  6. Amazon Fire HD 10 Front Facing Camera Replacement: passo 6, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement: passo 6, imagem 2 %32
    • Lift the black plastic cover once the screws are removed.
    • Place aside for later reassembly.
  7. Amazon Fire HD 10 Front Facing Camera Replacement: passo 7, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement: passo 7, imagem 2 %32
    • Detach the connector using a plastic opening tool or spudger.
    • The camera is still connected to the motherboard.
  8. Amazon Fire HD 10 Front Facing Camera Replacement: passo 8, imagem 1 %32 Amazon Fire HD 10 Front Facing Camera Replacement: passo 8, imagem 2 %32
    • Grip the camera and lift up to detach the ZIF connector from the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Jaie Hillery
Membro desde: 10/07/14
1.718 Reputação
Autoria de 10 guias
Equipe
USF Tampa, Team 16-6, Blackwell Winter 2016 Membro de USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
Membros da 3
Autoria de 22 guias
Um comentário
Can this camera module be upgraded with a better version?
Jimmy Kee - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,116
