Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
O que você precisa
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
11 outras pessoas executaram este guia.
8 comentários
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
ctgblue -
How do you know if ita battery or charging port? Mine dont do anything whe. Its
