Introdução
This guide will show you how to replace the woofer, the speaker in the Amazon Echo responsible for the low-frequency bass. This guide should be helpful if your Echo is lacking bass or sounds otherwise distorted.
O que você precisa
Peel off the rubber footing from the bottom of the Echo.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Uma outra pessoa concluiu este guia.
3 comentários
Where can you buy a replacement woofer?
My exact question.
