Ir para o conteúdo principal
Amazon Echo Woofer Replacement
O que você precisa
  1. Amazon Echo Woofer Replacement, Power and Speaker Driver Board: passo 1, imagem 1 %32
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
    Pergunte ao FixBot
    Comentar
  2. Amazon Echo Woofer Replacement: passo 2, imagem 1 %32 Amazon Echo Woofer Replacement: passo 2, imagem 2 %32 Amazon Echo Woofer Replacement: passo 2, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
    Pergunte ao FixBot
    Comentar
  3. Amazon Echo Woofer Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
    Pergunte ao FixBot
    Comentar
  4. Amazon Echo Woofer Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Pergunte ao FixBot
    Comentar
  5. Amazon Echo Woofer Replacement: passo 5, imagem 1 %32 Amazon Echo Woofer Replacement: passo 5, imagem 2 %32
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
    Pergunte ao FixBot
    Comentar
  6. Amazon Echo Woofer Replacement: passo 6, imagem 1 %32 Amazon Echo Woofer Replacement: passo 6, imagem 2 %32 Amazon Echo Woofer Replacement: passo 6, imagem 3 %32
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    Pergunte ao FixBot
    Comentar
  7. Amazon Echo Woofer Replacement, Tweeter Assembly: passo 7, imagem 1 %32 Amazon Echo Woofer Replacement, Tweeter Assembly: passo 7, imagem 2 %32
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
    Pergunte ao FixBot
    Comentar
  8. Amazon Echo Woofer Replacement: passo 8, imagem 1 %32
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
    Pergunte ao FixBot
    Comentar
  9. Amazon Echo Woofer Replacement: passo 9, imagem 1 %32 Amazon Echo Woofer Replacement: passo 9, imagem 2 %32 Amazon Echo Woofer Replacement: passo 9, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
    Pergunte ao FixBot
    Comentar
  10. Amazon Echo Woofer Replacement, Woofer: passo 10, imagem 1 %32
    • Lift the woofer out of the Echo.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
4 Membros
Autoria de 13 guias
3Comentários do guia
Where can you buy a replacement woofer?
adam mierzwa - Responder Compartilhar
My exact question.
Marty Koenig - Responder Compartilhar
Could you post the dimension of the woofer unit? Its depth and diameter (and possibly screw holes location/diameter)? That would be very useful. Thank you.
No Body - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 52
Ao todo: 8,578
