Introdução
This guide demonstrates how to replace the tweeter in the Amazon Echo. This speaker delivers the higher pitched sounds when the Echo talks to you or plays any audio. This guide should be helpful if the audio from your Echo sounds distorted.
O que você precisa
Peel off the rubber footing from the bottom of the Echo.
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
Using a spudger or your fingers, pull back the plastic clips near the edge of the tweeter.
Remove the tweeter from its plastic housing.
Uma outra pessoa concluiu este guia.
3 comentários
Anyone know where to get a replacement tweeter?
Can anyone provide me the spare tweeter of Amazon echo dot 3rd generation
