Ir para o conteúdo principal
Amazon Echo Tweeter Assembly Replacement
O que você precisa
  1. Amazon Echo Tweeter Assembly Replacement, Power and Speaker Driver Board: passo 1, imagem 1 %32
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Tweeter Assembly Replacement: passo 2, imagem 1 %32 Amazon Echo Tweeter Assembly Replacement: passo 2, imagem 2 %32 Amazon Echo Tweeter Assembly Replacement: passo 2, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Tweeter Assembly Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Tweeter Assembly Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Tweeter Assembly Replacement: passo 5, imagem 1 %32 Amazon Echo Tweeter Assembly Replacement: passo 5, imagem 2 %32
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Tweeter Assembly Replacement: passo 6, imagem 1 %32 Amazon Echo Tweeter Assembly Replacement: passo 6, imagem 2 %32 Amazon Echo Tweeter Assembly Replacement: passo 6, imagem 3 %32
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: passo 7, imagem 1 %32 Amazon Echo Tweeter Assembly Replacement, Tweeter Assembly: passo 7, imagem 2 %32
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Tweeter Assembly Replacement: passo 8, imagem 1 %32
    • Peel off the black fabric wrapped around the Echo.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Tweeter Assembly Replacement: passo 9, imagem 1 %32 Amazon Echo Tweeter Assembly Replacement: passo 9, imagem 2 %32 Amazon Echo Tweeter Assembly Replacement: passo 9, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws around the tweeter.
    • Lift the tweeter and its attached housing from the device.
Conclusão
Alexander Albert
Membro desde: 02/04/16
1.145 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
Membros da 4
Autoria de 12 guias
3 comentários
I've gotten this far, but where do you get a replacement? No brand or model # on tweeter.
Kyle - Responder
Are you saying removing it and replacing the same tweeter is what you have to do? It says no parts.
kathy1557 - Responder
The primary purpose of this guide is to show you how to remove a failing tweeter so that you can replace it with a new one. The "no parts required" text appears at the top of this guide because the author didn't have a source for the replacement part.
Ron Davis -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 16
Duração total: 3,710
