Introdução
This guide will help you access and remove the top and side speakers in order to replace them.
O que você precisa
Flip the device upside down.
Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
Remove the two screws located across from each other on the outside of the plastic ring shown.
Remove the plastic outer ring that hugs the inside of the edges of the device.
On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
After removing the motherboard, you should be able to see both of the side speakers and top speaker.
You will need to find and remove six 10mm screws to take off the top speaker's cover.
Uma outra pessoa concluiu este guia.
