Ir para o conteúdo principal
Amazon Echo Show Back Cover Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Amazon Echo Show Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 Amazon Echo Show Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Using your hands, gently remove the taped-in rubber foot from device.
    Pergunte ao FixBot
    Comentar
  2. Amazon Echo Show Back Cover Replacement: passo 2, imagem 1 %32 Amazon Echo Show Back Cover Replacement: passo 2, imagem 2 %32
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
    Pergunte ao FixBot
    Comentar
  3. Amazon Echo Show Back Cover Replacement: passo 3, imagem 1 %32
    • After the screws are removed, grip the front panel and remove, using a plastic opening tool if necessary. This will expose the inside of the device.
    Pergunte ao FixBot
    Comentar
  4. Amazon Echo Show Back Cover Replacement: passo 4, imagem 1 %32 Amazon Echo Show Back Cover Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Repeat this step for the other speaker, and lay the front section flat with the facing down.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    Pergunte ao FixBot
    Comentar
Conclusão
2Comentários do guia
this particular guide originally only had the prerequisite guide portion, so the steps to replace the top buttons were repeated across every single guide we had. I adjusted the prerequisite guide to include the separation of the two halves and moved the top button replacement guide to its own page. As this is still a private guide, it won’t be published unless we approve it.
Justin Williams - Responder Compartilhar
This article has been flagged as the prerequisite guide for a few of our articles, so I ended up altering it to be such. However, the ones that are not linked to this one, I added a few steps.
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 617
