Introdução
This guide is to show how to replace a damaged or dirty sound foam case on the Echo Show 2nd gen device.
O que você precisa
Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
Pull each of the plugs out.
