Introdução
This is a step-by-step guide to show how to remove the circuit board that is attached to the speakers. It can be done in just a few simple steps with the help of a spudger and a few screw drivers.
O que você precisa
Turn the two screw plugs counterclockwise with a metal spudger until they are 90 degrees from their original position.
Pull each of the plugs out.
Unscrew the white case using the TR1 screwdriver bit to remove the 4mm screws.
Pull on the top until the case becomes fully dislodged.
