Ir para o conteúdo principal
Amazon Echo Show 15 Microphone Replacement
O que você precisa
  1. Amazon Echo Show 15 Microphone Replacement, Back Panel: passo 1, imagem 1 %32 Amazon Echo Show 15 Microphone Replacement, Back Panel: passo 1, imagem 2 %32 Amazon Echo Show 15 Microphone Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
  2. Amazon Echo Show 15 Microphone Replacement: passo 2, imagem 1 %32 Amazon Echo Show 15 Microphone Replacement: passo 2, imagem 2 %32 Amazon Echo Show 15 Microphone Replacement: passo 2, imagem 3 %32
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
  3. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: passo 3, imagem 1 %32 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: passo 3, imagem 2 %32 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: passo 3, imagem 3 %32
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
  4. Amazon Echo Show 15 Microphone Replacement, Microphone: passo 4, imagem 1 %32 Amazon Echo Show 15 Microphone Replacement, Microphone: passo 4, imagem 2 %32
    • Locate the microphone panel on the top right hand corner.
    • Remove the two 3 mm screws with a Torx T3 screwdriver.
  5. Amazon Echo Show 15 Microphone Replacement: passo 5, imagem 1 %32 Amazon Echo Show 15 Microphone Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the microphone.
    • You may use tweezers for this step if necessary.
Conclusão
Talara
Membro desde: 09/20/23
318 Reputação
Autoria de 3 guias
Equipe
2Comentários do guia
Great tutorial. One question though, where do you get the new microphone?
Trevor Richardson - Responder Compartilhar
Hi what is the other wire on the top that displays mic as well ?
Eddy Elias - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 52
Ao todo: 635
