Ir para o conteúdo principal
Amazon Echo Show 15 Camera Replacement
O que você precisa
  1. Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, imagem 1 %32 Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, imagem 2 %32 Amazon Echo Show 15 Camera Replacement, Back Panel: passo 1, imagem 3 %32
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    Pergunte ao FixBot
    Comentar
  2. Amazon Echo Show 15 Camera Replacement: passo 2, imagem 1 %32 Amazon Echo Show 15 Camera Replacement: passo 2, imagem 2 %32 Amazon Echo Show 15 Camera Replacement: passo 2, imagem 3 %32
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    Pergunte ao FixBot
    Comentar
  3. Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, imagem 1 %32 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, imagem 2 %32 Amazon Echo Show 15 Camera Replacement, Inner Black Panel: passo 3, imagem 3 %32
    • In the top right corner you will find a small black panel.
    • Remove the five 2 mm screws with a Torx T5 screwdriver.
    • Remove the two 5 mm with a Torx T3 screwdriver.
    • Remove both ends of the connector from the main device.
    • Remove the black panel.
    Pergunte ao FixBot
    Comentar
  4. Amazon Echo Show 15 Camera Replacement, Camera: passo 4, imagem 1 %32 Amazon Echo Show 15 Camera Replacement, Camera: passo 4, imagem 2 %32 Amazon Echo Show 15 Camera Replacement, Camera: passo 4, imagem 3 %32
    • Remove the small connector from the main device.
    • Disconnect the camera cord from the motherboard.
    • Pull the camera out of the main device.
    • The camera is connected to the main device with adhesive. You will need to use a bit more force to get it out.
    Pergunte ao FixBot
    Comentar
Conclusão
Paysen Hudson
Membro desde: 09/20/23
208 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 21
Ao todo: 363
