Ir para o conteúdo principal
Amazon Echo Motherboard Replacement
O que você precisa
  1. Amazon Echo Motherboard Replacement, Power and Speaker Driver Board: passo 1, imagem 1 %32
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Motherboard Replacement: passo 2, imagem 1 %32 Amazon Echo Motherboard Replacement: passo 2, imagem 2 %32 Amazon Echo Motherboard Replacement: passo 2, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Motherboard Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Motherboard Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo Motherboard Replacement: passo 5, imagem 1 %32 Amazon Echo Motherboard Replacement: passo 5, imagem 2 %32
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Motherboard Replacement: passo 6, imagem 1 %32 Amazon Echo Motherboard Replacement: passo 6, imagem 2 %32 Amazon Echo Motherboard Replacement: passo 6, imagem 3 %32
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 Amazon Echo Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo Motherboard Replacement: passo 8, imagem 1 %32
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo Motherboard Replacement: passo 9, imagem 1 %32 Amazon Echo Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo Motherboard Replacement: passo 10, imagem 1 %32 Amazon Echo Motherboard Replacement: passo 10, imagem 2 %32 Amazon Echo Motherboard Replacement: passo 10, imagem 3 %32
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo Motherboard Replacement: passo 11, imagem 1 %32
    • Lift the motherboard up from the Echo.
Conclusão
4 outras pessoas executaram este guia.
Alexander Albert
Membro desde: 02/04/16
1.145 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
Membros da 4
Autoria de 12 guias
11 comentários
Where can you get the mmotherboard
Glen Seay - Responder
same question. where do i get replacement motherboard?
akn978s - Responder
This is how to remove the motherboard not how to replace it....geez
adairt - Responder
There is a reason why people look for information on how to remove it; and that is … TO REPLACE IT! So, where can you get a replacement?
arcsnsparks2000 - Responder
So no place to buy the motherboard, iv striped it down but can’t buy the board anywhere
mark crewe - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 66
Duração total: 14,782
