Introdução
This guide demonstrates how to remove the LED/Microphone board. This board contains the LED indication ring at the top of the Echo, as well as the seven microphone array. This guide should assist you if the LED ring is malfunctioning or if the Echo has issues hearing you.
O que você precisa
Peel off the rubber footing from the bottom of the Echo.
Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
Könnt ihr Ersatzteil machen für Amazon Echo
Wo kann ich Ersatzteile holen für Amazon Echo
Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
Using the spudger, pull back the two plastic clips on the plate.
Lift the board up and pull it away from the plate.
I need to find a replacement board. Where can I find one?
Me to, i need this board to my alexa echo
Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
These instructions are not going to help me because I am trying to repair an Alexa Echo Show.
Lift the motherboard up from the Echo.
Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
Turn the assembly over and lift up the plate with the buttons.
Please where can i get this top part to buy, mine is broken
Came here to say the same… where can I buy the top plate with the buttons? Mine was dropped and broke off at the studs. Ifixit it looks like a part that has demand.
Remove the ribbon cable by lifting the brown latch on the ZIF connector.
Lift the LED/Microphone board from the plate.
Where can I buy the volume assembly? My echo fell from a shelf and it broke of and shattered.
6 outras pessoas executaram este guia.
2 comentários
Where can i buy this LED/Microphone board for replacement?
