Ir para o conteúdo principal
Amazon Echo LED/Microphone Board Replacement
O que você precisa
  1. Amazon Echo LED/Microphone Board Replacement, Power and Speaker Driver Board: passo 1, imagem 1 %32
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo LED/Microphone Board Replacement: passo 2, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 2, imagem 2 %32 Amazon Echo LED/Microphone Board Replacement: passo 2, imagem 3 %32
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo LED/Microphone Board Replacement: passo 3, imagem 1 %32
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo LED/Microphone Board Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
  5. Amazon Echo LED/Microphone Board Replacement: passo 5, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 5, imagem 2 %32
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo LED/Microphone Board Replacement: passo 6, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 6, imagem 2 %32 Amazon Echo LED/Microphone Board Replacement: passo 6, imagem 3 %32
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
  7. Amazon Echo LED/Microphone Board Replacement, Motherboard: passo 7, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement, Motherboard: passo 7, imagem 2 %32
    • Remove the plastic plate from the bottom of the device. Then remove the plastic shrouding.
  8. Amazon Echo LED/Microphone Board Replacement: passo 8, imagem 1 %32
    • Peel off the black fabric wrapped around the device.
    • Be careful not to rip the fabric. Use a spudger to help remove the adhesive if you have any trouble.
  9. Amazon Echo LED/Microphone Board Replacement: passo 9, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 9, imagem 2 %32
    • Remove the four 9.7 mm T10 screws.
  10. Amazon Echo LED/Microphone Board Replacement: passo 10, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 10, imagem 2 %32 Amazon Echo LED/Microphone Board Replacement: passo 10, imagem 3 %32
    • Lift the brown and black plastic latches securing the ZIF connectors at each end of the motherboard.
    • Pull the two ribbon cables from their connectors on the motherboard.
  11. Amazon Echo LED/Microphone Board Replacement: passo 11, imagem 1 %32
    • Lift the motherboard up from the Echo.
  12. Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: passo 12, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement, LED/Microphone Board: passo 12, imagem 2 %32
    • Remove the 9.7 mm T10 Torx screw from the opposite side of the Echo.
  13. Amazon Echo LED/Microphone Board Replacement: passo 13, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 13, imagem 2 %32
    • Unclip and remove the top volume ring assembly from the Echo.
  14. Amazon Echo LED/Microphone Board Replacement: passo 14, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 14, imagem 2 %32
    • Unscrew the four 9.7 mm T9 torx screws from the bottom of the volume ring assembly.
  15. Amazon Echo LED/Microphone Board Replacement: passo 15, imagem 1 %32
    • Turn the assembly over and lift up the plate with the buttons.
  16. Amazon Echo LED/Microphone Board Replacement: passo 16, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 16, imagem 2 %32
    • Turn the plate over, then lift and remove black gear and the white plastic ring.
  17. Amazon Echo LED/Microphone Board Replacement: passo 17, imagem 1 %32 Amazon Echo LED/Microphone Board Replacement: passo 17, imagem 2 %32 Amazon Echo LED/Microphone Board Replacement: passo 17, imagem 3 %32
    • Remove the ribbon cable by lifting the brown latch on the ZIF connector.
    • Lift the LED/Microphone board from the plate.
Conclusão
6 outras pessoas executaram este guia.
Alexander Albert
Membro desde: 02/04/16
1.145 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 3-3, Wollert Spring 2016 Membro de USF Tampa, Team 3-3, Wollert Spring 2016
USFT-WOLLERT-S16S3G3
Membros da 4
Autoria de 12 guias
2 comentários
So in Step 15, I’m having a problem reassembling the Plate with buttons back into the volume ring… can someone give me any tricks/pointers please?
JaxyB - Responder
Where can i buy this LED/Microphone board for replacement?
Tuan Nguyen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 49
Duração total: 13,893
