Ir para o conteúdo principal
Amazon Echo Dot 3rd Generation Motherboard Replacement
O que você precisa
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: passo 1, imagem 1 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: passo 1, imagem 2 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: passo 1, imagem 3 %32
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 2, imagem 2 %32
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 3, imagem 1 %32
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 4, imagem 1 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 4, imagem 2 %32
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: passo 5, imagem 1 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: passo 5, imagem 2 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: passo 5, imagem 3 %32
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 6, imagem 1 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 6, imagem 2 %32 Amazon Echo Dot 3rd Generation Motherboard Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
Conclusão
3Comentários do guia
Where do we get the parts you bi chh
Fcukermother - Responder
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 31
Últimos 30 dias: 148
Ao todo: 2,899
