Ir para o conteúdo principal
Amazon Echo Dot 3rd Generation Casing Replacement
O que você precisa
  1. Amazon Echo Dot 3rd Generation Casing Replacement, Casing: passo 1, imagem 1 %32 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: passo 1, imagem 2 %32 Amazon Echo Dot 3rd Generation Casing Replacement, Casing: passo 1, imagem 3 %32
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Casing Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 3rd Generation Casing Replacement: passo 2, imagem 2 %32
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Casing Replacement: passo 3, imagem 1 %32
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Casing Replacement: passo 4, imagem 1 %32 Amazon Echo Dot 3rd Generation Casing Replacement: passo 4, imagem 2 %32
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
Conclusão
To reassemble your Echo Dot, follow these instructions in reverse order. Ensure the casing fits properly before tightening the screws back on. Once reassembly is finished, check that the device powers on and functions correctly.
Kristen Gismondi
Membro desde: 11/12/14
99.517 Reputação
Autoria de 255 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.726 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 44
Ao todo: 1,154
