Ir para o conteúdo principal
Amazon Echo Dot 3rd Gen Disassembly
O que você precisa
  1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: passo 1, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: passo 1, imagem 2 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: passo 1, imagem 3 %32
    • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
    • Avoid letting the Adhesive touch anything, lay the plate on the branded side
    • If the adhesive is to strong use a hair dryer to soften it
  2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: passo 2, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: passo 2, imagem 2 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: passo 2, imagem 3 %32
    • Use a TORX T6H bit to remove the four screws on the bottom
    • When all the screws are taken out lift up and the covering should slide off
  3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: passo 3, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: passo 3, imagem 2 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: passo 3, imagem 3 %32
    • Remember to un latch the ribbon cable before pulling the circuit board up
  4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: passo 4, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: passo 4, imagem 2 %32 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: passo 4, imagem 3 %32
    • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
    • Pull up on the metal to release the top from the rest
  5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: passo 5, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: passo 5, imagem 2 %32 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: passo 5, imagem 3 %32
    • Undo the four screws the remove the white defuser piece (I lost a screw)
  6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: passo 6, imagem 1 %32 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: passo 6, imagem 2 %32
    • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
Conclusão
6 outras pessoas executaram este guia.
Ben Nicholsonb
Membro desde: 07/09/21
322 Reputação
Autoria de 1 guia
3Comentários do guia
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - Responder
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - Responder
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - Responder
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 102
Últimos 30 dias: 440
Ao todo: 15,719
