Ir para o conteúdo principal
Amazon Echo Dot 2nd Generation Speaker Replacement
O que você precisa
  1. Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: passo 1, imagem 1 %32 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: passo 1, imagem 2 %32 Amazon Echo Dot 2nd Generation Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Speaker Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 2nd Generation Speaker Replacement: passo 2, imagem 2 %32 Amazon Echo Dot 2nd Generation Speaker Replacement: passo 2, imagem 3 %32
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black, cylindrical base
  3. Amazon Echo Dot 2nd Generation Speaker Replacement: passo 3, imagem 1 %32
    • Tap the base against the palm of your hand so that the black speaker component comes out
Conclusão
18 outras pessoas executaram este guia.
Alexis White
Membro desde: 10/09/17
577 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Membros
Autoria de 12 guias
3Comentários do guia
Where can one purchase the replacement speaker component?
ananomaus - Responder
Can you inform us were to get replacement speaker please.
John Stead - Responder
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
Meghan Craig - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 53
Ao todo: 14,129
