Introdução
Use this guide to replace the ribbon cable in the Amazon Echo Dot 2nd Generation.
O que você precisa
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
4 outras pessoas executaram este guia.
5 comentários
Where do you get the replacement cable from?
Yes, where can one get replacement ribbon cables?
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
no cable available, just waiting for donors
