Ir para o conteúdo principal
Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
O que você precisa
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, imagem 1 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, imagem 2 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: passo 1, imagem 3 %32
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, imagem 2 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 2, imagem 3 %32
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, imagem 1 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, imagem 2 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 3, imagem 3 %32
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 4, imagem 1 %32
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, imagem 1 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, imagem 2 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 5, imagem 3 %32
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, imagem 1 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, imagem 2 %32 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: passo 6, imagem 3 %32
    • Remove the ribbon cable from the slot on the LED/speaker board
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
Membros da 3
Autoria de 12 guias
5 comentários
Where do you get the replacement cable from?
jonathan kabitzke - Responder
Yes, where can one get replacement ribbon cables?
Armando Morreale - Responder
Malcolm oakley - Responder
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Responder
no cable available, just waiting for donors
Ray Floyd Cabrera - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 29
Duração total: 2,440
