Introdução
Use this guide to replace the LED/speaker and microphone board in the Amazon Echo Dot 2nd generation. Both the LED, speaker, and microphone are located on the same board within the device. The whole board must be replaced, rather than each individual component.
O que você precisa
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
4 outras pessoas executaram este guia.
1Comentário do guia
I can’t seem to find the board anywhere. Where would you buy one?
