Ir para o conteúdo principal
Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement
O que você precisa
  1. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, imagem 1 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, imagem 2 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement, LED/Speaker Board and Microphone: passo 1, imagem 3 %32
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo.
  2. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, imagem 2 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 2, imagem 3 %32
    • Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, imagem 1 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, imagem 2 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 3, imagem 3 %32
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 4, imagem 1 %32
    • Remove the motherboard
  5. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, imagem 1 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, imagem 2 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 5, imagem 3 %32
    • Remove the silver divider
    • Remove black rubber divider
    • Remove the plastic white frame
  6. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, imagem 1 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, imagem 2 %32 Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 6, imagem 3 %32
    • Remove the ribbon cable from the slot on the LED/speaker board
  7. Amazon Echo Dot 2nd Generation LED/Speaker Board and Microphone Replacement: passo 7, imagem 1 %32
    • Remove the LED/speaker board
Conclusão
4 outras pessoas executaram este guia.
Cassidy O'Connor
Membro desde: 10/09/17
450 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
Membros da 3
Autoria de 12 guias
Um comentário
I can’t seem to find the board anywhere. Where would you buy one?
George hanes - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 18
Duração total: 4,942
