Ir para o conteúdo principal
Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement
O que você precisa
  1. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, imagem 1 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, imagem 2 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement, 4-in-1 WiFi/Bluetooth/FM/GPS: passo 1, imagem 3 %32
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
  2. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, imagem 1 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, imagem 2 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 2, imagem 3 %32
    • Use a T8 screwdriver bit to unscrew the four 1.6mm torx screws
    • Remove the black cylindrical base
  3. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, imagem 1 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, imagem 2 %32 Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 3, imagem 3 %32
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
  4. Amazon Echo Dot 2nd Generation 4-in-1 WiFi/Bluetooth/FM/GPS Replacement: passo 4, imagem 1 %32
    • Remove the motherboard
Conclusão
7 outras pessoas executaram este guia.
Alexis White
Membro desde: 10/09/17
505 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S1-G3, Leahy Fall 2017 Membro de USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
Membros da 3
Autoria de 12 guias
2 comentários
Where can I find the part my dot won’t connect and I have been going crazy trying to find the motherboard
Ivy Bowman - Responder
I wish to recommend not removing the adhesive layer if you plan to reassemble this Echo Dot. I would suggest poking holes to reach the four screws instead. Then reassembly can reuse the same adhesive layer.
rayramirez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 30
Duração total: 6,288
