Ir para o conteúdo principal
Aluratek ADMPF310F Screen Replacement
O que você precisa
  1. Aluratek ADMPF310F Screen Replacement, Screen: passo 1, imagem 1 %32 Aluratek ADMPF310F Screen Replacement, Screen: passo 1, imagem 2 %32 Aluratek ADMPF310F Screen Replacement, Screen: passo 1, imagem 3 %32
    • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
    • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
  2. Aluratek ADMPF310F Screen Replacement: passo 2, imagem 1 %32
    • Lift screen out of place so you can access the plugs that connect it.
    • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
  3. Aluratek ADMPF310F Screen Replacement: passo 3, imagem 1 %32 Aluratek ADMPF310F Screen Replacement: passo 3, imagem 2 %32
    • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
    • Pull the ribbon cable away from the motherboard.
    • Be careful as this clip is very frail.
  4. Aluratek ADMPF310F Screen Replacement: passo 4, imagem 1 %32
    • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
Conclusão
Chris Belair
Membro desde: 10/20/16
333 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 5-1, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 412
