Introdução
Remove and replace alternator on a Briggs and Stratton 5.5 horsepower lawnmower engine.
O que você precisa
Push the metal tab closest to the black wire down. While pushing the tab down, pull the black wire out of the clip.
Using a 1/4 socket, remove the two bolts holding the alternator to the engine.
From the alternator side, gently pull the black wire out past the cylinder it is routed under on the engine.
