Ir para o conteúdo principal
Altec Lansing inMotion iM9 Volume and Power Buttons Replacement
O que você precisa
  1. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Battery: passo 1, imagem 1 %32
    • Gently push down on the two tabs at the top of the battery door.
    • While holding them down, slowly pull the door towards you.
  2. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: passo 2, imagem 1 %32
    • Once the door is open, use your hand to pull out the four batteries.
  3. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: passo 3, imagem 1 %32 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement, Volume and Power Buttons: passo 3, imagem 2 %32
    • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
    • Start in the middle and work your way around the perimeter.
  4. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: passo 4, imagem 1 %32 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: passo 4, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
    • Also remove the single 7mm screw from the power button circuit board on the opposite side.
    • There will be a little plastic piece under the eject button that you can just remove and set aside.
  5. Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: passo 5, imagem 1 %32 Altec Lansing inMotion iM9 Volume and Power Buttons Replacement: passo 5, imagem 2 %32
    • Desolder the three solders joints connecting the wires to the volume button circuit board.
    • Do the same to the power button circuit board on the other side (the board with only one screw).
    • Pull out the wires using a lot of force.
    • If you are not familiar or comfortable with soldering, use this guide
Conclusão
Ben Toland
Membro desde: 02/01/15
101 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 17-33, Amido Winter 2015 Membro de Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,449
