Introdução
If the battery in your Altec Lansing Mini Lifejacket 2 isn't holding a charge or is showing signs of failure, use this guide to replace it.
O que você precisa
Use the spudger to remove the eight black pins from the front and back of the wire screens.
7 outras pessoas executaram este guia.
10 comentários
Search for MCR18650 battery. They are available.
Hickisch, I appreciate your guide on replacing this battery, but I beg to differ that replacement batteries are “available.” I keep getting sent batteries with 3-wire connectors instead of 2-wire. Plz send me a link, plz. Gracias.
for the mini life jacket 3, the motherboard is upside down so you need to remove it to unplug the battery.
For the mini life jacket 3 can you send what link you had for the battery?
