Ir para o conteúdo principal
Altec Lansing BoomJacket Speaker Replacement
O que você precisa
  1. Altec Lansing BoomJacket Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Speaker Replacement: passo 2, imagem 1 %32
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Speaker Replacement: passo 3, imagem 1 %32
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Speaker Replacement: passo 4, imagem 1 %32
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Speaker Replacement: passo 5, imagem 1 %32 Altec Lansing BoomJacket Speaker Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Speaker Replacement: passo 6, imagem 1 %32
    • Using the size PH1 screwdriver remove the screws (4 around each speaker).
  7. Altec Lansing BoomJacket Speaker Replacement: passo 7, imagem 1 %32
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Speaker Replacement: passo 8, imagem 1 %32
    • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
Conclusão
2 comentários
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Responder
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 754
