Ir para o conteúdo principal
Altec Lansing BoomJacket Battery Replacement
O que você precisa
  1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: passo 1, imagem 1 %32
    • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
  2. Altec Lansing BoomJacket Battery  Replacement: passo 2, imagem 1 %32
    • Remove the outer black rubber housing of the speaker.
  3. Altec Lansing BoomJacket Battery  Replacement: passo 3, imagem 1 %32
    • Remove the inner blue rubber housing from the speaker.
  4. Altec Lansing BoomJacket Battery  Replacement: passo 4, imagem 1 %32
    • Pull out the two black wire meshes using a metal spudger.
    • Be careful not to damage the metal casing.
  5. Altec Lansing BoomJacket Battery  Replacement: passo 5, imagem 1 %32 Altec Lansing BoomJacket Battery  Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
  6. Altec Lansing BoomJacket Battery  Replacement: passo 6, imagem 1 %32
    • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
  7. Altec Lansing BoomJacket Battery  Replacement: passo 7, imagem 1 %32
    • Pull the case apart and you will be able to see all the components inside the speaker.
  8. Altec Lansing BoomJacket Battery  Replacement, Battery: passo 8, imagem 1 %32
    • The battery will be sitting right behind the speakers when the case is open.
  9. Altec Lansing BoomJacket Battery  Replacement: passo 9, imagem 1 %32
    • Unplug and disconnect the battery from the motherboard.
Conclusão
5 outras pessoas executaram este guia.
6 comentários
Where can you buy a replacement battery?
Darrell riley - Responder
Where can you buy the battery please?
Juan Roa - Responder
Where can I find ghe batteries? What type of battery ?
Violet Roach - Responder
where ca i buy a replacement battery
Shelley Franck - Responder
This tutorial is incomplete.
Ivan Rodriguez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 82
Duração total: 14,612
