Ir para o conteúdo principal
Altec Lansing BoomJacket 2 Speaker Replacement
O que você precisa
  1. Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 1 %32 Altec Lansing BoomJacket 2 Speaker Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 2 %32
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Speaker Replacement: passo 2, imagem 1 %32 Altec Lansing BoomJacket 2 Speaker Replacement: passo 2, imagem 2 %32
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Speaker Replacement: passo 3, imagem 1 %32
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Speaker Replacement: passo 4, imagem 1 %32 Altec Lansing BoomJacket 2 Speaker Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Speaker Replacement: passo 5, imagem 1 %32
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Speaker Replacement: passo 6, imagem 1 %32
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: passo 7, imagem 1 %32 Altec Lansing BoomJacket 2 Speaker Replacement, Speaker: passo 7, imagem 2 %32
    • Unscrew the four screws holding the speaker in place.
  8. Altec Lansing BoomJacket 2 Speaker Replacement: passo 8, imagem 1 %32 Altec Lansing BoomJacket 2 Speaker Replacement: passo 8, imagem 2 %32
    • Unscrew the two screws on the smaller speaker.
    • Pull the small speaker through the larger speaker hole.
Conclusão
Uma outra pessoa concluiu este guia.
Zach Braaten
Membro desde: 07/12/18
516 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 458
