Ir para o conteúdo principal
Altec Lansing BoomJacket 2 Battery Replacement
O que você precisa
  1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 1 %32 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: passo 1, imagem 2 %32
    • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
  2. Altec Lansing BoomJacket 2 Battery Replacement: passo 2, imagem 1 %32 Altec Lansing BoomJacket 2 Battery Replacement: passo 2, imagem 2 %32
    • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
  3. Altec Lansing BoomJacket 2 Battery Replacement: passo 3, imagem 1 %32
    • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
    • Avoid using excessive force to prevent bending the grill.
  4. Altec Lansing BoomJacket 2 Battery Replacement: passo 4, imagem 1 %32 Altec Lansing BoomJacket 2 Battery Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
  5. Altec Lansing BoomJacket 2 Battery Replacement: passo 5, imagem 1 %32
    • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
  6. Altec Lansing BoomJacket 2 Battery Replacement: passo 6, imagem 1 %32
    • Gently pull apart the front panel from the base of the speaker.
  7. Altec Lansing BoomJacket 2 Battery Replacement, Battery: passo 7, imagem 1 %32
    • The battery will be in the middle of the speaker when the case is open.
  8. Altec Lansing BoomJacket 2 Battery Replacement: passo 8, imagem 1 %32
    • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
    • Pull battery up and away from speaker without catching any other components.
    • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
Conclusão
Uma outra pessoa concluiu este guia.
Zach Braaten
Membro desde: 07/12/18
516 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 27
Duração total: 1,489
