Ir para o conteúdo principal
Alpine MRV-M500 Electrolytic Capacitor Replacement
O que você precisa
  1. Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, imagem 1 %32 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, imagem 2 %32 Alpine MRV-M500 Electrolytic Capacitor Replacement, Electrolytic Capacitor: passo 1, imagem 3 %32
    • Remove all the Phillips 10.0mm and 7.0mm screws on the outside of the case.
    • Make sure the device has been powered off and disconnected from the power source for at least a day before touching the electronic components.
  2. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, imagem 1 %32 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, imagem 2 %32 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 2, imagem 3 %32
    • Remove all Phillips 7.5mm, 12.5mm, and 10.5mm screws holding the circuit board to the case.
    • Remove the circuit board from the case.
  3. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 3, imagem 1 %32 Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 3, imagem 2 %32
    • Find the faulty capacitor.
    • Flip the board over and locate the corresponding pins.
    • If the faulty capacitor is one of the smaller ones, it may be too difficult to replace and replacing the circuit board itself may be easier.
    • Make sure that the capacitance and voltage rating of the new capacitor match that of the original.
  4. Alpine MRV-M500 Electrolytic Capacitor Replacement: passo 4, imagem 1 %32
    • Desolder the pins to remove the capacitor.
    • Solder the new capacitor into its place.
    • Make sure the polarity of the new capacitor matches the previous polarity.
Conclusão
3 outras pessoas executaram este guia.
Eric Gaulke
Membro desde: 09/17/18
623 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 1,548
